I’m ready to purchase the new Max 4 laser cutter/engraver, but I want to know if I can fit the NEJE Air Assist Set to protect the laser module to this particular machine? I know it comes as a separate accesory, but I’m not sure if it can be added to the Max 4 Machine, any help with this matter will be greatly appreciated.
Yes, the high-pressure air pump is very helpful for cutting, so that the cutting edge is clean and the cutting efficiency will be improved. If you use the built-in air pump, you need a clean air source. If you use the needle tube type, the air source is not required. It is best Air pressure greater than 30PSI,Ordinary AOC aquarium air pump is only for lens protection
This can only be used as lens protection, and does not improve cutting efficiency much, especially for high-density materials
Something like this, an air compressor greater than 30PSI (but needs a well-working oil-water separator)
Thank you very much for the info, I will order the 24v electronic Valve you showed me first, and since I do have a compressor like the one you showed me, I will hook that 24 volt valve to the compressor when my machine arrives. Thank you very much for the information!
What i would like to know, is that it says it’s “without oil” that means i would not need a filer?
Also if i use this compressor, should i use the needle-type air assist? Or the built-in airpump?
Also i got a bit mixed in the replies and don’t understand the following:
If i use the needle-type air assist, the cutting will not improve? It’s used only to keep the lens clean?
The bottom line, is that i want to buy something that will also help me improve the cutting.
L.E. i also found this one that seems to be with oil?
@Jim thank you for your reply, but could you tell me if either of this models are good to use directly without the needle-type?
I did not give direct links to the product page, as i do not know if it’s allowed, so that’s why i made a screenshot that shows the model, that way, the specification can be found online.
If the one without oil would also be good, that means that i also need a oil-water separator for that one also?
P.S. The cleaning part of the lens is clear and noted.
Thank you for the video. So bith of them are around 100psi so it should be good.
And i understand that both can be connected directly to the E80 module if they have the oil-water separator and the cutting will improve, correct?
Coming back, i decided to go for a 50l 8 bar oul compressor with air-oil filter.
What i want to know, as i could not really find online:
On neje max 3, i saw that you need an additional module that controlls the air output.
Do i need that, or do i just need to connect it to the connector next to that Y axis?
Also dont understand the M8 and M7 setting as seen in the neje 3max air assist install
Also on fb group, someone said that i should limit the output of the PSI, so not to use the total 100PSI, but to limit it. He said he has a 90PSI and limited it to 30 PSI, should that be done?
The reason is that you would cool the wood too much.
Is there a file with sized for drag chain? I would like to make one, as the free cables on the neje 4max are making me feel uncomfortable.
