Hi Will upgrading the motherboard on a neje master 2 solve the homing problems with lightburn? If so which motherboard is recommended?
Is there a problem with master 2 homing?
When using the neje software it is not a problem, but it doesnt work in lightburn
Have you already checked the NEJE Wiki?
Greetings
Coffee
To exit the NEJE software, you need to select the GRBL mode, and this switch to the lightburn software will be successful.
Many thanks Jim.
I will try this.
Best wishes
Paul
