software issue ???
i have only been able to get my machine to go home, and no further. this is the codes i get with error message.
NEJE v6.7.3.17654
TypeOf exception [System.NullReferenceException]
Exception message [Object reference not set to an instance of an object.]
Exception source [NEJE], thread
Exception method [Void MoveNext()]
----------- stack trace -----------
at NEJE.FormConn.<listBox_DoubleClick>d__15.MoveNext()
— End of stack trace from previous location where exception was thrown —
at System.Runtime.CompilerServices.AsyncMethodBuilderCore.<>c.b__6_0(Object state)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
at System.Windows.Threading.DispatcherOperation.InvokeImpl()
at System.Windows.Threading.DispatcherOperation.InvokeInSecurityContext(Object state)
at MS.Internal.CulturePreservingExecutionContext.CallbackWrapper(Object obj)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at MS.Internal.CulturePreservingExecutionContext.Run(CulturePreservingExecutionContext executionContext, ContextCallback callback, Object state)
at System.Windows.Threading.DispatcherOperation.Invoke()
at System.Windows.Threading.Dispatcher.ProcessQueue()
at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr dwComponentID, Int32 reason, Int32 pvLoopData)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.RunDialog(Form form)
at System.Windows.Forms.Form.ShowDialog(IWin32Window owner)
at System.Windows.Forms.Form.ShowDialog()
at Library.View.FormWaiting.<>c__DisplayClass9_0.b__0()
at NEJE.FormMain.d__41.MoveNext()
at System.Windows.Forms.Application.Run(Form mainForm)
at NEJE.Program.Main(String args)
NEJE v6.7.3.17654
NEJE v6.7.3.17654
We are very sorry that you have encountered problems during use. Your detailed feedback will help us locate and fix it quickly, thank you for your support and cooperation.
To help us resolve issues most efficiently, please refer to the following checklist for information:
Mr Wong, you have everything i already have, software said contact support, their are three instances all three were screen shot and are pasted in my second message, all i have been able to do is send laser to home position then i get this error. REPEATEDLY, machine will not proceed any further. I am clueless as to the cause because i cannot read YOUR CODE. and i have a minor in robotics and machinist training in CNC, very very unhappy customer here. i simply want it to work, and all i have received is run around. i wish to use it to engrave glass bottles.
Could you send me a video about it?
If you don’t know how to add a video, this link may help you.
or
We are now in the stage of locating the problem, and once we have located the problem, we will fix it for you soon.
Thanks again
I have no video. I move assembly to a position somewhere in the middle of travel. Send it to home position..it travels to home position and give me the errors and that long script and instructs me to contact support..EVERY TIME IT GOES HOME I GET THE SAME ERROR. THEN IT CEASES TO RESPOND TO ANY COMMANDS
G.E.Dominy
Dear friends, can you provide a relevant video? Only if we reproduce the problem can you fix it.
