Will there be somewhere a list with the settings (passes/speed etc.) for different materials for a NEJE 3 MAX?
There are no specific parameters recommended, because different densities and grades of materials will bring different parameter settings
Hello Stephan Saggau,
welcome to the forum. Reference values for engraving and cutting are only available in relation to the laser module used. Which framework you use is secondary.
Check out the NEJE WIKI if you have a NEJE laser module.
Greetings Coffee
