Questo e il motore del Rotary della sculpfun
I don’t know how many amps are on the motor labels. Wait and see if Jim or Jack know.
While you wait, ask the seller.
Il motore è 1A
Then you have to remove a resistor with a tin soldering iron.
Keep one thing in mind: the soldering iron melts the tin underneath the resistor very quickly, so you need tweezers to remove the resistor as quickly as possible.
And now you can work. Start the rotary and check the engine temperature.
E quale resistore devo togliere
Casomai la numero 3 se il motore è 1A
I told you to remove the first one from the right, point.
But I see you didn’t read this article I sent you 7 days ago, point.
That link you see now is within the first link I sent you 7 days ago.
Last paragraph.
You're welcome.
@Giovanni, Once you have assembled the rotary axis:You let it rest, if you see that it gets hot, contact us.That is, without turning the rotary.
If the rotary device has a normal temperature when left at rest, then:
We start to rotate the rotary, for example, at a speed of 300 mm/min and control the temperature from time to time.
If you think it’s getting hot then please let us know.
I already have experience in all this and have done many tests.
