problem setting up new neje max 4 v2 with lightburn
Hi, just set up new neje max4 v2 and when trying to work with lightburn the machine will not home correctly. It stops in random places on the left side. Framing just makes the machine grind. Does anyone have the settings required for setup please,
"Please check two aspects:
First, verify that the motor control cables (Y1, Y2, etc.) are connected to the correct ports and not swapped.
Second, check if the mechanical movement is smooth. If it feels stiff or rough, inspect whether the eccentric spacers (rollers) are too tight or if the timing belt tension is too high, causing resistance."
