@Jim I have noticed that all documented NEJE cutting charts mention as a example 3ply Speed 120 Power 100% 1 pass
but all staff always tell us not to use 100% power, instead of trying to make out how strong your laser are, how about redoing all charts and say recommended Power & Speed
Such as…
3 Ply Speed 120 Power 80% 4 passes is only a guide, please test your own laser, you can start at 80% 4 passes but adjust for your own laser module
Your suggestion is good, because a little error can lead to different results, we will adjust the direction of the suggestion
I appreciate that and so will other’s
thank you very much
It needs to be combined with the power of the module, as well as air-assisted air pressure, cutting speed, etc. There is no fixed value, but I recommend adjusting the speed a little faster, 2pass, 90% power, 5-8bar (clean with oil-water separator Air source, high pressure air pump)
