Is there an on/off switch on the NEJE 3 Max?
There is a tiny button on the main board but it doesn’t do anything.
I believe you are talking about the limit switch for the home position
Bonjour. il faut rester appuyer quelques secondes soit pour l’allumer soit pour l’retreindre.
Hello
I have purchased this item last week and built it today however it won’t turn off unless I unplug it other wise the red light in the top and the laser light stays on ?
When I try to turn it off it home’s the goes to the middle and starts to doing a little square then light burn says gbrl is turned off you need to switch to gbrl ?
I’m not sure if there is a problem with this machine
