Nozzle got stuck
I have one of the nozzle stuck, any tip besides the alcohol
It’s mostly grease buildup — regular household degreaser should do the trick.
Hello again, can you explain how to use the household products. Is really stuck . And I urgently need to use for a business project.
Remove the nozzle, soak or wipe it with degreaser, then reinstall it.
Hi. Thank you for responding, that is not the problem, the problem is that the nozzle got stuck. I’ve use the laser 3 times.
