I use Lightburn for my Neje Max4 E80.
My question is, is there a “Lightburn Material Library” available for this machine?
You can refer to the project suggestions here
I found the best way is to do a material test for each material I use and build a library that way. It would be tailored to your setup then.
regards
Its under the window tab at the top of lightburn.
