Neje max 4, Controlboard/laser suddently dead?
Hi there.
Yesterday I was making a lasercut, when the the laser apparently stopped moving. When checking the cut I could see it had just started the task, when it looked as if the laser got stock, and burned the wood, and afterwards the laser had stopped.
Following this, the machine had big problems navigating, especially the Y axis. When I homed the laser at 0/0, made a Frame command, it would move and draw the frame correctly, but then make the position it had moved to, on the Y axis, the new 0. I tried resetting GRBL, updating firmware, turning the machine on/off several times and also using USB instead of BT that seemed to had become somewhat unreliable. In that process I moved my PC forgetting the cable for the USB, which resulted in the USB port on the controlboard being ripped off. So in any case I need a new controlboard.
But my laser module may need replacement aswell. There is no (blue) light, and when starting a test task, there is no laseroutput. Also it keeps making a small continuous clicking from the Z axis motor.
So my questions are; Any idea what could have happend? And when ordering the controlboard, might I aswell just order a new lasermodule? It has only been used for less than a year!? I also bought a new controlboard as the original never worked…
Best Regards
Bjarne Sorensen
Hello.Please provide a video of the machine malfunction and a screenshot of the order.
Hey Liya
I have just ordered a new controlboard, and will try this first. I am not at home currently, so can not make a video. Lets see if the laser will behave with a new controlboard.
Best Regards
Bjarne
Okay,if any question you can contact store customer service.
Hi again.
Just replaced the Controlboard, unfortunately without any change. I have tried making a video, showing the controlboard status and you can hear the click sounds in the background, when connected to BT. Then I plug in the USB and it keeps clicking but not so loud.
I also did a powertest using USb. It failed with an errormessage “Minimum power voltage 2,5V”
On the Troubleshooting page, under information and Laser Info, i can see that it says “Connected: NO” and no info available.
If you need more info or video, please let me know what you specific need.
I thank you in advance.
/Bjarne
LINK TO VIDEO: Unique Download Link | WeTransfer
It sounds a bit like the motors fire up, attempt to lock, then drop?
can you easliy push the carriage after switch on? i.e. does it feel like the motors are locked? this is assuming you have them set to be always locked…which is $1=255
Please run this test. Your laser module may have a short circuit.
