Good morning ! I ordered a new Neje Master 2S with N46030 module. Hailea model ACO-318, 45W compressor is one commonly use with Neje. I do not do cutting of plywood the exceed 4mm. Can I use Hailea modelo ACO-308, 30W instead. Thank you.
The air compressor of this model may be a little under pressure.
