Hello Neje Team
I have big problem with my 2Smax machine. The ch340 chip which is used to translate usb to serial on the motherboard is not supported in the last win 11 system.
I tried many drivers and solutions but machine doesn’t work in Win11 24H2. In pc with older Win 11 distribution, the machine work correctly. Do you have any solution for this issue? I use Lightburn or GRBL to check and both fails.
