Update
I found the issue was a quick easy fix after searching the forum.
The motor cable got disconnected from the mother board somehow.
I reconnected it and it works fine now.
If you want, you can delete the topic or leave it if someone has the same issue.
Hi
So my engraving started to come out with what looks like lines, gaps in the image. I uploaded some examples.
The machine is Neje 3 Max v2
I noticed that the right side motor won’t get locked, when the machine is on, as it supposed to. So I think it may be related.
