Hi ,
I hope someone can help with this question…
I am looking for a motherboard for neje master 2s max,
It seems neje does not have that in stock….
Could I order a motherboard for a neje 3 max instead?
What is the difference between the two?
Hi ,
@Arnimarkus
Hi, sorry this new motherboard hasn’t started fa’shou
What is that?
I have found it online to order, would this work?
Yes, NEJE 3 max works. Please change the wiring of the two Y axes.
Ok, thanks…
Do you mean that I should switch the two, or do i need to reconnect the wires in the plug?
Best regards,
Arni
reconnect the wires in the plug, It’s easy don’t worry.
Hi !
I have now received the new neje 3max motherboard,
What exactly must I change in the wiring?
I assume you don’t mean to switch the two from left to right?
Sorry for late.
You can see Y-R and Y-L on your control board, connect Y-L to your left motor, connect Y-R to your right motor, please do a motor test after.
https://neje99.com/faq/how-to-test-motor-at-grbl.html
