M7 output
hi. is it possible to get M7 output to turn on, when the laser is turn on?
neje max4.
Yes, It is possible to turn it on and off in G-code.. in laser GRBL you can put an M7 in the start code, and an M9 in the end code, which turns off both M7 and M8
I use M7 and M8 for air bleed (a slow bleed of air to keep lens cleaner whislt engraving).
And air assist, high flow air for cutting..
I combine the extraction fan output with the bleed air, and a delay at the end to turn off the fan output
