I’ve had this laser for about 4 or 5 years and never had any issues with it. I recently turned it on and it has lost coordinates. It goes the wrong direction and is going out of bounds and grinding. I don’t know why it would just do this out of the blue. I have always had it set to home upon startup. I’m in need od some help please.
Hi Dropenelk,
Do you have a saved copy of all of your lasers settings? i.e. all of the $values.. If so you should check them against what is stored in it now.
It sounds as though they have been corrupted or reset.
$23 inverts the homing direction. $23=0 is non inverted, $23=1 is inverted.
$3 inverts the direction of each axis $3=nnn, where nnn is the addition of each axis x is 1, y is 2, z is 4
if they have been corrupted, then likely accel vales are changed as well
Could you please send screenshots of your Homing Settings ($23) and Motor Direction settings ($3)? I can help you restore the correct parameters. Also, keep in mind that “out of bounds” errors can sometimes be caused by excessive Scan Overlap.
