laser module
I currenty lave this (NEJE Master 2S Max Engraving Machine, CNC Engraver and Cutter for Plywood, Unfinished Wood,App Control with Lightburn and GRBL, 7.5W Output, 46
ASIN: B08NP9852H) laser and would like to upgrade. Will (NEJE A40640 Zoom Laser Module for Carving and Cutting - 2 x beam - 12W output - Widely Applied) work on my machine?
What is the main purpose of your work? The E40 laser module is a fixed-focus laser module, good at cutting materials below 4mm, with high cutting precision and fine engraving. A40640 is a zoom laser module. It is relatively difficult to use, but it can be adjusted and has wider applicability. Your master 2S machine can be used, and the power supply needs to be upgraded to 12V 5A
