Hi folks i just purchased the neje master 2s plus laser and although the setup was easy, the arm travels too far when i go to frame an object the laser runs into the frame.
Thanks
Kevin
Thanks
Kevin
What software are you using? Are you homing first?
You might have to configure machine area and soft limits.
I don’t have this machine, just the laser, but if it’s a GRBL loaded board you should have those options?.
Похоже, что у нас общая проблема. Я её определил как проблема оси Y. По какой то причине начало отсчёта по этой оси начинается с конца (420 мм - зона оси Y).
This link may help you:
https://neje99.com/troubleshooting/troubleshooting-of-grbl.html
