Hello i have the neje 3 app is it possible to change ? The laser power always starts at 100% ? And is it possible to change the preview mode that it not automaticly stops? Both just like in the neje2 app. I have ios and it often closes by itself when i push start ?
Should be able to use NEJE 2 APP
https://neje99.com/software/neje-control-software-for-ios-macos.html
It does not work,
He says is not supported download neje app 3
What is your machine model?
NEJE 3 PLUS N40630
The laser power can be adjusted in the software settings, can’t yours be adjusted? Can you send me your breakdown video?
If you don’t know how to upload video, The following link may be helpful:
https://neje99.com/forum/how-to-attach-a-video-when-i-post.html
Best wishes.
I can set the laser power but each time when i open the app for a new project the laserpower is 100% again? When i make several the same things then i often forget to set the laserpower back ![]()
and when i put the object under it i have the open the preview mode several time so that the object is in the wright place
After the preview, you can still adjust the laser power
thats wright but in the neje 2 app the preview mode stays on (so you can lay the object at the best place) and stays the laserpower the same in a new session.
Can you take a video and show me?
Best wishes.
