Can i convert the laser signal when its fires the beam to a 12v connected to relay . In order to connect a device that will work only when the relay is closed
Don’t understand what you mean, you can refer to this link
https://neje99.com/faq/how-to-make-laser-module-work-with-your-control-board.html
I have a neje that the laser is 4 wiers and i need to have a laser 12v 2 wiers mean convert from 4 wiers to 2 wiers ( i will connect it to relay that will start other things
Can’t convert 4pin to 2pin
I see
So what is the board named
Laser module interface adapter
This is for non-NEJE machines or for module testing
