Hi,
I’ve been asked to help someone with an upgrade due to a failed laser.
The initial product is a Master 7w with a NEJE Master board ( No version number. )
Upgrade parts are as follows
Air Assist.
NEJE E40
NEJE Laser Module Tester v1.31
NEJE Laser Adapter v1.2
I’ve had a look round and it’s as clear as mud as to how to upgrade this.
I know I can use the Adapter or the module tester to control the laser with its own power supply.
It’s not clear ( because none of the ports are labeled on the master board ) What plugs into what. On the original set up there is a combined cable that controls the limit switch, laser and the y axis motor. there are several empty ports on the board but it’s not clear what any of these do.
I suspect he needs a different motherboard?
Could someone help please?
Thanks
