I’ve a pretty old (possibly around 2018) NEJE Mini laser Carver which I don’t use since a while. On the PCB is written V1.3.1. The laser has no power on/off, just the direct power cable to USB and the interface cable to USB .
I’m not able to install the proper driver, can’t find. Actually, even when inserting the interface USB my camputer doesn’t react. I’m using a laptop with windows 7 64bit professional. I don’t know also which software to use, I’ve found in the neje99.com some (very) old software for windows but none was able to work (and to install the driver).
Many years ago it was working, and I stored it properly…
Anyway, when I plug the input power the blue laser turn on.
Thank you very much for your help
