Couple of quick questions regarding accessories for MAX 4
Due to a project, I need to order a laser cutter right away. I have several 3D printers and a CNC router and am pretty proficient in F360. However, I’ve never used a laser cutter/engraver. So, I have a couple noob questions and limited time for research. I need the Max 4 with extensions. What else do I need to order? I assume an air pump. And something to place under the laser since the honeycomb panel offered by Neje doesn’t appear large enough for the Max 4 with extension kit. Maybe standoffs? I’ll build my own encloser since I do a lot of woodworking. Do I need additional drag chain for the extension kit or other items (besides Lightburn)? Any help appreciated.
  1. If you have an air pump compressor with air filtration, then you don’t need to buy an air pump
  2. You can buy two honeycomb panels to fill
