Hi, when should I change the lenses of E80? How should I know?
But how do I know it’s time to change?
Under normal circumstances, it is enough to clean the protective lens. If the protective lens is burned, it needs to be replaced. Burned protective lenses are usually caused by not cleaning the lens in time, causing the lens to absorb the laser and generate high temperature and burn.
