8x FAC Optics & 0.09mm Precision: The NEJE E160 Deep Dive.
Introducing the NEJE E160 Module
The Powerhouse. Redefined.
Core Performance
  • **Electrical Power:**​ 160W | **Optical Output:**​ >50W
  • **Spot Size:**​ 0.09 x 0.09 mm (Ultra-fine)
  • **Cutting Ability:**​ Silky smooth cutting on Carbon Steel​ & HDF.
  • **Precision:**​ Renders crisp 0.5mm text​ with zero distortion.
Revolutionary Optics & Design
  • **8x FAC + Complex Lens Tech:**​ Proprietary optical system for extreme density.
  • **Lighter than E80:**​ Minimizes inertia, fully unleashing motion performance.
  • **Sealed Liquid Cooling:**​ Fully enclosed, oil & smoke proof. Zero maintenance.
Smart Safety & Control
  • **LightBurn Integration:**​ Auto-pause on overheat to prevent cooling failures.
  • **Over-Temp Protection:**​ Safeguards against accidents.
  • **3m Industrial Cable:**​ Compatible with various machine setups.
Endurance & Reliability
  • **200M+ Lifespan:**​ Validated by 20,000 hours of lab testing.
  • **Heavy-Duty Motion Cable:**​ Engineered for relentless movement.
  • **56L/min Pump Support:**​ Ensures sustained peak performance.
  • **Warranty:**​ 2-Year Free Warranty.
What are your thoughts on the features and expected price? Also, should the package include essential accessories like the water pump, 48V 400W power supply, and air assist?
Wow! Cool.
The package should have the option of each accessory to be added. Some (eventually) may wish to just replace, or build their own system.
Do these cables and pipes have the ability to be run in a cable chain?
What thickness of carbon steel are you saying can be cut? with what sort of air pressure?
I am interested in the ability to mark out..i.e. centre punch with a laser for drill holes on plate steel. Will that be possible on thick plate?
looks a bit like the E80 at the work end, is this going to be the same protective lens system?
And will it have a bit more height than the E80 to work surface, mine is 22mm / ramp test, with far less from the nozzle itself.
Peter
I will complete the test and get back to you with the results.
Thank you.
In my opinion it should have everything that is required by the proprietary system. For example, what use is selling it without the cooling pump if that specific pump is required for its proper functioning? If any pump can be used instead, then go right ahead and sell it solo. But if, on the other hand, the module requires that particular pump and that particular power supply unit, then buying the module alone means we can’t use it. So it’s useless to buy it without the accessories.
Something very important in my opinion: if the module price will be over $800, you should extend the warranty to 3 years. It is a groundbreaking module on paper but at the same time it will most likely have the price of a new machine. So the buyers should have some extra insurance. Maybe 2-year full warranty and a third year of limited warranty or something like that.
Looks great, looking forward for more details.
