Hi hamayome,
if you work with a Windows PC, the main memory is also used as a buffer for data transfer. If you use other programs during a laser job, the data connection may be lost. With larger laser jobs, it can also be due to the energy settings of Win that the job is not processed further because the PC goes into stand-by mode.
What has often happened, the USB connection is interrupted / loose contact.
Those would be the points that should be clarified first.
Greetings
Coffee
pc 와 usb케이블을 새로 교체를 하고 작업을 시도했으나 작업5분정도 지나면 갑자기 메세지와함께 멈추게됩니다. pc는 다른프로그램을 동시에 사용하지 않습니다. 잦은 멈춤으로 제품 불량이 너무 많아 스트레스가 너무 큽니다.
