NEJE N30610 – how to remove the brass laser diode cartridge?
Hi! I have an older NEJE N30610 7W laser module and I am trying to understand how the laser diode assembly is constructed.
The 5.6 mm laser diode appears to be mounted inside a brass/copper cylindrical cartridge, which is inserted into the aluminum heatsink.
Could you please clarify:
  • Is this brass cartridge press-fitted into the aluminum body, threaded, glued, or otherwise mechanically locked?
  • In which direction should the cartridge be removed?
  • Is it safe to press it out from the rear side?
  • Is the 5.6 mm laser diode itself press-fitted into the brass cartridge and replaceable?
I am not trying to increase the laser power - I mainly want to understand the mechanical construction and whether the diode can be serviced/replaced without damaging the module.
If you have an assembly drawing, cross-section, or service information for the N30610, that would be very helpful.
Thank you!
